See that's where Infiniti told me something different. They told me the transmission fluid in the 2nd gen can be changed every 45K-50K. Its actually listed under periodic maintenance in the factory service manual. All fluid eventually breaks down under constant use and especially at temperatures that the transmission operates at.BMW tried this whole lifetime fluid thing and people's transmission started slipping and stuff and there were lawsuits because by the time it came to actually change the fluid it was too late. I would never wait 100K miles to change the fluid. by then you won't even be able to change it as it would make the problem worse. I heard people say if the fluid hasn't been changed for so long and there is already problems flushing it would make it worse.
Aaron, I know the Infiniti by you does BG because that is what they put in yours without you knowing at first. If you do BG you need to change every 45k-50k....minimum I would say. Every dealer and every Infiniti guy you talk to will say something different...their opinion. If they typically do BG then that is what they have in their mind and that is just what they say. You'll find most people say that either to get the sale or if they are good people, because simply they don't necessarily know what every owner had their trans changed with last time.
You'd be shocked to see what kind of ridiculous extremes tests engineers do in transmission plants and across in the world in different climates, etc. Transmissions are typically built to last several numerous 100s of thousands of miles. They can put those kind of strains quickly on a trans. They also test the break down of fluids among other things and usually significantly overestimate when things need changing but do so just to cover everybody's butt because some people do push the envelope. Just because a fluid is dirty or changes viscosity soon after doesn't mean it needs changing...in fact sometimes its better to let it sit at that spot in viscosity longer because that is more so what it's designed to be in.
You could change your oil every 2,000 miles, trans every 30k miles, and on and on....it's better than not doing it for 200k miles. But you seriously don't have to. I prefer not to overkill it, even though I feel like I do already with doing stuff with maintenance exactly when it is scheduled, but I also do that for the warranty purpose.
Don't compare BMW with Nissan...you should know better silly guy! Those engines and those transmissions are like comparing apples and kiwis.
---------- Post Merged at 12:46 PM ---------- Previous Post was at 12:36 PM ----------
What else did the head mechanic tell you and service intervals other than don't change the Trans fluid until 100K miles?
One thing that had struck me (but of course now I don't remember the details), he anticipates Infiniti may change engine oil interval recommendations sometime in the future because the engines on some of the new Infinitis (I think the Gs and Ms?) are not lasting between oil changes and they are coming out hinting at the first stages of sludge or something. Something about the viscosity of engine oil too. Honestly don't remember now.
If you have AWD, we don't necessarily have to run immediately and get the AWD service every 30k....60k would be ok with what he's seen based on the fact that our systems don't engage in AWD as much as we think.
