TPMS Sensor Display Help (please)
Squishymedic
New England
So I switched over to my Blizzaks for the winter and I can't get rid of the "low pressure icon" on the dash. I access the tire sensor display screen and there are just asterisks *** near each tire. I cannot access thee fields. Does this mean the computer isn't reading the sensors?
I presume that to change those fields,you just dial down or arrow down once you get to that screen,,correct?
Any help would meet with an abundance of joy.
-C
So you moved them to your winter wheels? If that's the case, it should work. Have you driven on them at all? Sometimes it takes a few miles to recognize them. Did you drive without them at any point?
Doesn't sound like a battery issue if all of them don't show pressure.
As I can remember, our car only recognize one set (4 sensors) at a time. Since your has been programmed with your summer wheels, it is normal that it will not recognize the sensors in your winter wheels.
Some tire place can program the two set of sensors using one set of ID code so that it doesn't matter which set of tire you're running it will properly display the tire pressure.
