front caliper 14mm ratchet socket or wrench, rotor 17mm or 19mm socket for rotors, c clamp for piston compression.
rear caliper 14mm wrench only, the bottom bolt is not accessible with a ratchet socket, rotors 17 or 19mm, c clamp for piston
---------- Post Merged at 02:30 PM ---------- Previous Post was at 02:29 PM ----------
breaker bar and hammer if your not using pneumatic tool
---------- Post Merged at 02:37 PM ---------- Previous Post was at 02:29 PM ----------
edit and correction on rotor socket size
Front: 22mm socket
Rear: 19mm socket
