throttle Body Replacement
Jdiamond
Bronx NY
I need to replace the throttle Body on my 2004 FX35, I have a p2135 code. I did some research and it seems the code is pertaining to the tp sensor but the sensor is built into the whole throttle body, does anybody have any idea on how to remove and replace the throttle body, additonally I was told once replaced the new throttle body has to be calibrated to the car, is there any truth to that, and once replaced will the computer recognize and reset.
Here's a thread on removing it, it's easy enough if you have the right tools. I think it's hex keys you need. Install is reverse. Probably need to calibrate it when it's on just to be safe, I know every time I cleaned mine I needed to, so it seems they are sensitive. You can go with a refurb, but I have one from Logan that was bored out and I guess was a dud, but the company wouldn't exchange it since it was modified. It's going to be a paperweight at some point for me I guess, no, a conversation piece!
https://www.infinitiscene.com/search/1/?q=21274-Removing-the-Throttle-Body
We'll I replaced my t/b and the c/e lights still I still don't have power if my headlights or on do I need to delete the code in order for it to run rite?
No, the CEL will remain sometimes even if you no longer have the code. It's just there until you reset it. But resetting the code would have nothing to do with your car running properly. ie, if you fixed the problem, the car would run fine but the light would still be there. So you're still having some sort of problem.
