View attachment 249626 ITB06-027 Service Campaign View attachment 249627
2003–2006 INFINITI FX; VOLUNTARY SERVICE CAMPAIGN REAR COMBINATION LAMP Nissan has determined that on some model Year 2003-2006 Infiniti FX35/45 vehicles, the rear combination lamps fail to comply with certain requirements set forth in Federal Motor Vehicle Safety Standard (FMVSS) No.108. The standard specifies, among other things, the performance requirements for rear stop, tail, and turn signal lamps for passenger vehicles. One of these requirements specifies their minimum light intensity at certain test points. The rear combination lamps in vehicles subject to this TSB may not meet these requirements. This means that the stop, tail, and turn signal lamp function may be too dim when viewed at certain angles. Reduced visibility increases the risk of the vehicle being involved in a crash. To correct this Condition, Nissan is conducting a Voluntary Recall Campaign to replace the existing rear combination lamps with new and compliant lamps free of charge |
