sunroof switch malfunction(my fault)
david
mississippi
ok when i did my interior color change i had the assembly with the switch and dome lights out. I taped off the lights and sprayed the assembly black. I assume i used too much paint and it got inside?? I hooked it up the next day and now my sunroof doesnt work. Where can i buy a replacement switch? Or any ideas on how to fix it??
Thanks
I would image that if some paint spray got into a connector it would be noticable as strangely tight to fit back together. Is it possible you missed a connection? Check and recheck?
Or a wire got pinched during reassembly. Open it back up and make sure nothing is crimped.
