Quick question for everyone. Is there a way to adjust the track on the sunroof. When I shut mine it closes, but does not raise all of the way up. It is about 3/8" from being flush with the roof line. Any help would be appreciated.
I don't know personally, but it will probably involve removing the whole headliner and then maybe you will be able to access something to adjust the alignment of the sunroof.
Just wanted to give an update. Finally got around to looking at the sunroof. It has two Torx screws on each side (front & rear) I simply loosened the front screws and pushed the sunroof back up into the original factory position. It now is flush with the roof, which also eliminated the wind noise. It took me 2 minutes to adjust.
