EC06-004 ITB06-012 May 24, 2006
TICKING NOISE FROM ENGINE AREA
APPLIED VEHICLE(S):2003-2006 G35 (V35 and CV35),
2002-2006 Q45 (F50),
2003-2006 FX35/45 (S50),
2003-2004 M45 (Y34),
2006 M35/45 (Y50)
IF YOU CONFIRM
There is a ticking, clicking, thumping, or knocking noise heard in the passenger compartment at idle. The noisecould be from the engine compartment.
ACTION
•With the engine idling, feel the fuel damper hose while the noise is occurring.
The fuel damper hose is located on the Bank 1 side of the engine.
All V6 vehicles Passenger side
All V8 vehicles Driver side of engine
Figure 1
•If the vibration of the fuel damper hose coincides with the noise heard inside the vehicle, replace the fuel
damper and attached hose on that cylinder bank (Bank 1).
•See the respective ESM and Engine Mechanical (EM) section for replacement of the damper with hose.
•Confirm the noise at idle from the passenger compartment is not present.
Infiniti Bulletinsare intended for use by qualified technicians, not 'do-it-yourselfers'. Qualified technicians are properly trained
individuals who have the equipment, tools, safety instruction, and know-how to do a job properly and safely. NOTE: If you believe
that a described condition may apply to a particular vehicle, DO NOT assume that it does. See your Infiniti dealer to determine if thisapplies to your vehicle.
1/2
PARTS INFORMATION
PARTS INFORMATION
PART#QUANTITY
Fuel damper (FX35, M35, G35, G35 Coupe)22675-AM60A1
Fuel damper (Q45, FX45) (sop-05MY)22675-CR91A1
Fuel damper (M45 (all MY) , FX45 (2006 MY), Q45 (2006 MY))22675-EH00A1
CLAIMS INFORMATION
Submit a Primary Failed Part (PP) line claim using the following claims coding:
DESCRIPTIONPFPOPCODESYMDIAFRTRPL One Fuel Damper Assy (1) FX22AA ZL 32 0.7 hrs (FX35,M35,G35)
0.5 hrs (FX45, M45, Q45)
(1) Reference the Parts Information Table and use the applicable Fuel Damper P/N as the PFP.
2/2
