Stock FX35 Tires (265 50R20) on Nissan OEM GTR rims
chips
Miami
Hello all,
I just purchased a set of Nissan OEM GTR wheels and I'm wondering if anyone has mounted their stock 265 50R20 tires on the GTR wheels? (fronts are 9.5 and the backs are 10.5"). Standard tire specs call for at least a 275 width for a 10.5.
The reason I ask is that I have a brand new set of the 265s on my stock FX35 rims and I'm trying to save a few bucks by mounting the tires that I have. Unless I can sell my OEM FX35 tires and rims together.
I'll get 295s for the rear wheels once the stock tires wear out.
If anyone has mounted the stock FX tires on GTR rims, can you post a pic?
I do not want the tires to look stretched.
Thank you,
Chips
---------- Post added at 03:12 PM ---------- Previous post was at 03:07 PM ----------
Here are the specs for my stock Bridgestone Dueler HP/92A tires. It looks like they are recommended up to 9.5, but I want to put them on a 10.5"
[TABLE="class: spectable"]
[TR="class: tab"]
[TD][/TD]
[TD="colspan: 12"][/TD]
[/TR]
[TR]
[TD="align: left"]Size
Service Description
Load Range[/TD]
[TD][/TD]
[TD][/TD]
[TD]Max.
Inflation
Press.[/TD]
[TD]Tread
Depth[/TD]
[TD]Tire
Weight[/TD]
[TD]Rim
Width
Range[/TD]
[TD]Meas.
Rim
Width[/TD]
[TD]Sect.
Width[/TD]
[TD]Tread
Width[/TD]
[TD]Overall
Diam.[/TD]
[TD]Revs
Per
Mile[/TD]
[TD]Country
of Origin*[/TD]
[/TR]
[TR]
[TD="width: 190"]265/50R20
Load Index 106 = 2094lbs (950kg) per tire
Speed Rating “V” = 149mph (240kph) 106V [/TD]
[TD][/TD]
[TD][/TD]
[TD]51 psi [/TD]
[TD]10/32" [/TD]
[TD]41 lbs.[/TD]
[TD]7.5-9.5" [/TD]
[TD]8.5" [/TD]
[TD]10.7" [/TD]
[TD]9.1" [/TD]
[TD]30.6" [/TD]
[TD]681 [/TD]
[TD]Country of Origin "JP" = JAPANJP[/TD]
[/TR]
[/TABLE]
can't run them all the way around if you have a staggered set up.. your answer lies in the rim width range of the 265/50r20.. it says its capable to run from a 7.5-9.5 in width wheel without compromise
Theres a member on here who has 265s on the rear gtr wheels and says they're fine
Hey guys I have 10.5 all around and I'm running a 255/45/20 up front 275/40/20 rear. I'm maxed out on my coils and don't want to raise the car back up. What size tire for the front will you guys recommend that will properly fit a 10.5 in rim without raising the car
