Stillen A/F
fxlr8
Staff
Administrator
I would love to get rid of the 7th injector and box. I sometimes worry the box isn't working... I ran the car with the cipher connected yesterday and just hitting around 6.5 psi boost my a/f was around 11.6..
Does this seem right? or is 11.6 lean?
I just emailed a rep at stillen.
Thank you for your inquiry!
That is just about perfect. We want between 11.2-11.7 on stage 4 to be safe.
The maximum boost (8psi) is at around 6500 rpm. Some cars will vary abit,
and headers, high flow cats etc will affect boost.
Hope that helps!
Looks like I am around the norm according to Stillen.
I probably need to test again hitting max boost at 8psi and compare again the a/f. What parameters should I log on cipher viet? I wish cipher could log boost.
I wish it could too. :(
I usually do the af ratios (have you entered the ecu mode yet?) coolant temps, intake temps, maf voltage, throttle position, vehicle speed, turbine revolutions, vehicle speed, and a few others depending on what I'm working on.
