Steering rack question
paullo
Boston
Sup folks , I have read the other post about the steering wheel shake at 60-65mph, I was under my car today and the big bolt on the steering rack is completely loose , question is , does it need to be all loose?? Cause I've tryed to tight and the st wheel became to heavy , than I turn the bolt back to its last position , but the shake remains there ....
what should I do?? Thx
That is the steering rack tension adjuster bolt it's not supposed to be tight.
Just tighten it snug then back the bolt out a quarter to half turn.
The steering wheel should move to center while driving when you let go of the steering wheel.
Try balancing your Tires that fixed my shaking completely and I haven't even tried the bolt yet, since that appeared to fix the problem. Also rotated my Tires
