stealthfx35
I ran into a strange problem today - this car has been working almost 2 years without any problems.
What I did was that I drove to work in the morning - everyhing was fine as always.
In the evening before leaving I removed the air filter - I had one compressor running and I just thought to give it a clean - just with air (in my workplace - away from my car)
After cleaning I put it back and started driving. Worked fine until - rushhour - had to stop an noticed that motor wants to stall - low rpms - uneven engine speed - switched to neutral and held rpms up with pushing a pedal slightly.
Managed to do that about 10 times until I got to Nissan Service.
My initial idea was that ok - I messed with the air filter - maybe I managed to block it somehow with compressed air and that is the reason why it wants to stall.
Bought a new one. Installed it and ... well nothing - it starts up nicely getting to 1000 rpms - in first second the engine sound is fine and steady - looks ok - but then it stalls.
Starts up without any hesitattion and stalls again - repeated that procedure about 30x - moved the wiring by hand around the air intake - no results.
Time to time I noticed that when it stalled the red key indication was blinking - but not every time. Battery is new and good and the car does not hesitate to start up
OK - that leaded me to conclusion that if it starts up it must be immobiliser that kills the engine.
Is there anything I can do during weekend or do I have to give my keys to the service guys first thing on Monday morning.
(things I did locally - resetted ecu with pedal combinations, took the battery wire off for 10 min, fiddled with every connector on the right side, changed the battery on the remote)
Any ideas?
Any ideas?
