Hey guys,
Hope some of you could chime in and help a fellow FXer with some weird issues.
Long story short, almost every morning when starting the FX, it starts but immediately feels like it will stall then idles fine. The cold weather seems to affect it more.
There's also an issue where after a good 15-20 minutes drive, if I park it for 20-30 minutes and try to start it, it will start and immediately die. What I would then do is try to restart it giving a few seconds in between until the sixth time it would actually maintain idle after struggling a bit.
Then I've had a few instances where the car would eventually go into limp mode after a good 15 minute drive where any form of accelerator input is delayed and not very reactive. It almost feels like the computer is preventing the engine from achieving any normal operator performance. Almost like having snow mode on but worse.
I'd right after move off the road, turn off the car and once again I wouldn't be able to start the car until the 6th try and it would still be in limp mode. I'm guessing because of the codes, the car's in a safe mode.
Then there's times a restart would clear the issue and the car would drive normally again.
I've had an opportunity to pop in an ODB2 while it went into limp mode and two codes would pop up. P0101 and P010B. When looking these up, has something to do with both MAF sensors. I took a peek a both sensors and didn't see anything wrong with them.
Honestly I'm not sure what exactly is the issue. I've check the sensors, filters, checked the wires. Reset the ECU, re-did all the Idle Air, etc relearning procedures and it just won't go away.
Any thoughts?
Any thoughts?
