F
Fire0nic3
Guest
Ughh just a couple of months ago my rear seats have been squeaking like crazy. It squeaks every time someone is sitting in it or not and when you go over bumps or slanted up and incline. They really squeak especially when the seats are reclined all the way back or even all the way forward. I brought it to the dealer and they located the problem. It turns out the seats rub up against the side panels in the rear. So they put some greasy leather conditioner on it and the noise "slightly" went away but it's still there. There is nothing they can really do and I believe them. Its just the way the rear seats were designed. They made those side panels too close the the seat which causes the friction and rubbing.
I even tried WD-40 rubbed in between the leather and side panels and that didn't help. Only thing that works is putting a microfiber towel in between the seat and panel. Then the noise completely goes way. I was thinking about using insulating felt like what the dealers use, but was looking for something less tacky since you would be able to see it when the seats are folded down.
This is the only real complaint I have. Otherwise the interior is quiet as a coffin.
