Spark plug seals question
JDMRyde
I intend to replace both valve cover gaskets on my vehicle, it's my understanding that the spark plug tube seals are molded into the underside of these covers. Consequently, the entire cover must be replaced, Nissan does not market replacement seals. Fel-Pro makes a "spark plug tube seal set", part number ES 72481 which are designed to replace the original seals, has anyone used them with success?
He's asking if we've the aftermarket spark plug seals by Fel Pro
Sent from my SGH-M919
so i got some seals from felpro but the ones on the cover dont come off lol and even if they did the ones that came with the felpro wouldnt fit. the felpro ones are bigger. so what i did was cut the ones on the cover off and used a dremal to widen the hole on the valve cover just enough so i can snug fit the rings that came with the felpro.
To prevent oil from getting into the spark plug chamber.. Instead of replacing the whole valve cover
