Smart remote and beepimg
Bernie
Tampa Florida
Drove to a local coffee shop and when I got out of the FX it started to beep.
Tried to lock the doors with the smart remote, however that reactivated the beeping, and what appeared to be a red icon of a battery was flashing on the dashboard.
I locked it with the key. Hour later I drove home.
Now it appears to lock and open OK with the remote.
Ideas?
Thanks
Some times it has a hickup like that..
Might be that you just need to replace your Smart Remote Battery...
Does the Inteligen Key Icon flash red when you are in the FX and flash at you while you are truning on your FX..? this is an indicator that you need to replace the battery..
good luck..
BTW, does the remote flash red, or an icon on the dashboard flash red?
On your Dash.. It displays it in the center between the Speed and RPM display.
You can't miss it.. It turns Green when you are in the car with it and it flashes red when you step out of the car while running....
That what was flashing and beeping. However now it appears to be OK.
I guess I will go with the fact that I did not turn it off completely when I got out:confused::confused:
