Hello,
I have an intermittent issue when turning at low speed or from standstill.
When making a tight turn, just after straightening up and applying throttle I hear a short (less than a second) high frequency buzz. A bit like tyre edge tread rubbing( but it isn't). The buzz is not felt through steering wheel. There isnt any crabbing or shaft windup but I think it is drive line related. Sound is a buzz and non metallic.
It does it more frequently after a long run ...checked brake rotors and they were cool. The buzz is not like abs kicking in....its higher frequency.
I'm going to change transfer case fluid (got 2 litres of matic J) ....does anyone have drawings or pictures of fill and drain plugs?
Any ideas / advice on what the issue might be?
Thanks
Thanks
