Just replaced my rear rotors and pads. Since then, the SLIP and VDC light will sometimes come on while I'm driving. No change in feel at all. There are times I'll drive without any warning lights coming on, but other times they come on as soon as I put the key in the ignition.
I have thought through a few of the possible causes, and also did a search for this same problem. Mine came after the rotors & pads were replaced, so I gotta think it's related.
1) Could I have put in the rear pads incorrectly? I noticed a metal "tang" on one of the pads that I read was supposed to be for a wear sensor. But I didn't see any mating parts. Could this be related?
2) I need to re-teach the brake pedal limits because the new rotor is a bit thicker than the OEM rotor I had turned down a couple times?
3) The parking brake doesn't like the new rotor?
I'd really love to know where the sensor is that triggers the SLIP light, and what it measures. Can somebody help me out with how to get rid of the lights so they function like they should in the future?
