Hello everybody,
I am new to this forum and will appreciate your help.
I have 2008 FX 35 with 125k mileage. Two days ago, I was driving on a high road and noticed that the AC is not cooling well (weather temperature was about 39degrees). I drove after this around 30 minutes, when I stopped on the Traffic Signal, the car sounded like it will shut off - engine RPM indicator was fluctuating below and above 1. Then, my eyes suddenly caught the temperature gauge on the Hot position (almost full).
I had to wait for a couple of minutes on this situation until the traffic signal is open and then I stopped on the right and immediately turned off the car. When I opened the engine area; radiator fans were working, but the radiator filler cap was producing like a compressed air releasing noise.
I waited for 15 minutes until the car is cool, and then I drove the car for about 10 minutes with low speed (60km/h). When I see the temperature gauge going above the middle point, I stop and turn the car off for another 15 minutes. I did that around 4 times until I reached the garage.
The technician told me that the Radiator is leaking and that there is, almost, no water in the radiator/cooling system. I was lucky that the head gasket is not blown and the engine is still working. He fixed the radiator and I got my car working as normal.
However, I am still anxious. Did this problem would have bad side-effects on the engine? Should I expect future issues with the car as a result of this problem? Did I follow the right practice in dealing with the over-heating problem?
Thank you for your help!
