rs r springs?
They make decent stuff, used to be big in the late 90's when the import craze was in full swing. They were Japanese, so you'd see a lot of their products around. Seemed to be high quality, never knew they made anything for the FX. But their US offices are 3 miles from Stillen, so maybe they put something together.
Thanks for the answer because i wanna get a little drop not too much because the camber issues so i wonder how much itll lower my car
I wonder the quality and performance between rs r and H&R too. I do like coilover but I dont want to be so low and damage the bottom of the car. Any experience for springs?
Sent from my LG-D851
I run the H&R's and am happy with the improvement to ride and handling on winding mountain roads. The springs coupled with some chassis bracing and wider lower profile tires have made my FX ride like its on rails through the tight corners!
The H&R's will give you about am 1 1/2" drop.
I did have to add camber adjustment kit to rear.
The beauty of coilovers is that you can set the height wherever you'd like. You can run them at OEM height or you can drop them all the way down.
How much did you pay for camber kit reat ?
