rotors
xratedfx
bklyn, nyc
hey just wondering, can the g35 coupe aftermarket rotors fit the fx?? i seen some really nice ones for the coupe and wonderind if it would fit??? thx guys.
2005-2006 front rotors from a g35 would fit a 2003-2005 front on the fx. Rears are different in all years. 2006+ fx is completely different from any year G. Check for yourself here:
g35: http://zeckhausen.com/Infiniti/G35-2.htm
fx35: http://zeckhausen.com/Infiniti/FX.htm
If you realize, the rotor type & dimensions are the same at the fronts for these two. Since the bolt pattern is the same, they should fit..
edit: +1 on Doc's comment though. Stick with fx ones. RotoPros (here are at the group buys section) is a good alternative if you need aftermarket rotors.
I've read some threads here regarding the rotors and it seems like alot of people are going for the rotorpro's rotor..I was wondering if the rotors come in different sizes for the different size rims..and can I get different brand calipers later if i wanted to??Like Im really interested in the Brembo calipers..can someone chime in??:smile:
As far as I know, no calipers except the OEM and known aftermarket ones FOR FX such as Stoptech, Rotora, Brembo etc will work. G35 Brembo calipers won't work with FX as well as their non-Brembo calipers. The mounting, ABS and caliper specs won't be the same as ours. You gotta get a kit specific for FX.
The RotoPros rotors comes only in stock sizes. The size of the front rotors for 03-05 and 06+ models are different so that's why they come in different sizes. They're not smaller/larger in diameter but 06+ are thicker.
If you want aftermarket look in your brakes, your best bet is either to paint them or to get a full aftermarket kit.
