Rim question.....
19 is a rough size for tires, most are too short. 8" wide +35 is an ok offset, it is 5mm closer to the wheel well than stock so not much of a change.
It really comes down to personal preference, lightweight 19's or 20's is always nice.
Just follow this rule,
19's-20's no lip
22+ lip
meaning do not get a lip unless you have 22's since the lip will really take away from the look of the size. As for a 19x8 you can probably go as low as a +15 offset on a 8" wide rim.
22 X 9 with 15+ offset will put you at max width without any rubbing issues and no wheel spacers needed so you can get more lip.
