rim info
slapp14me
watz up every1. new 2 forum & need 2 kno who has 24s on their fx? tire size? offset? is ur ride slammed? how wide can the rims be? do I need 2 get bigger brakes? by the way this is the best fx forum by far. thanks
don't think many have 24".. Not sure if it was bigmixx that wanted to try 24" but he ended up just doing 22". Most of us here don't think FXs look good with 24". But we would surely help you out if that what you want! Welcome to IS
I think the guy's handle is mosmike, or something like that. He has 24's (and I think he is thinking of selling)....you should look him up, for some info...
Need details on what you are interested in getting. There are too many combination variables to list. Please be more specific. Also check out the wheel section for ideas and pictures of member rides and what they have.
Welcome to the board.
Its a 05 Beryllium fx35 with just under 40k. picked up 4 21k. Im still not sure want I'll get but so far Im looking at some 24" lexani cs2 colored matched. 24x9.5 with 295/30/24. Yes I see that almost every1 here has 22s but Im going 4 that wow look. where Im at u see almost every car with 22s. I seen a fx with 26s on here but it was a show car. plus tire are like $1800 Im good. so 24s is wat it is. so please help me on this cause I really dont want 2 drop 5k on some rims that rub when I turn. I really need offsets and kno wat works/dosent. I would like the lip as big as I can go. again thanks every1 4 ur help.
Here's one from Cardomain
Member MrDeeAlexander can probably give you some info. He has buddies with 24s also.
I don't think rubbing is your main concern... I think your bigger concern would be bending your rims due to rubber band tires that you will have to use.
I think most people with oversized wheels regret their purchase once they find out they will have to repair their rims every other month...
if you can drop on the 24's then you in business but other than that depending on the wheel 22 looks small. In certain pic's the 22 looks good I have seen 1 black fx on black 24's and it look good but going with a thin tire will make you regret getting 24's I have 35 series pirelli's and i feel every bump in the road
have u bent any of ur rims with that series of tire. I've bent rims before but I was always in a rush 2 get everywhere... got kids now so no need to rush. hope I be good, cause rollin on stock is weak!
......welcome..... :laugh:
24's will surely stand out, just make sure you'll be able to live with the road feedback you'll be receiving from them. Good luck with your search :tup:.
Whats Up Slap....Things to think about, how will it look from all angles? will 24's look like they fit or will it look like a FX shell on big wheels? how much weight are you going to be carrying around? are you going to drop it? potholes? ride? Good luck in your search.
