Redline d4
DeadMaster
Canada, Vancouver, BC
2006 FX35
Hi Guys,
I was going to drain and fill my Transmission fluids tomorrow and was going to pick up 4L of RedLine D4.
This might be a dumb question but does anyone have the "part number" for this? Did a little bit of digging but i think this is the part number "30504" correct?
I will be going at a local mopac here in the city for these stuff.
Also if anyone has used this for their tranny drain and fill that can chime in on their experience with these fluid?
This can be mixed with the existing fluid that is currently on the car without any issues right?
Thanks in advance :iS:
D6 is supposed to be Matic S compatible. It's sort of weird that they rate the D4 as D, J, and K compatible when they're normally not. And the D6 is Matic S compatible when S is backwards compatible to J, but not the others. In the end, it doesn't matter that much. Any full synthetic is pretty universal. Matic J, S is just made by Castrol to JASO 1A standards. So just about any synthetic made to those same standards will work. I run Mobil1 right now without issues.
D4
Hi, I always use Redline D4 for my tranny..Great stuff as are all Redline oils..i use everything in my supercharged FX..
I have d4 in my transfer case. No issues at all, its been a solid 50k miles and its time to change it. Might go amsoil now because I can find it cheaper.
Redline fluids and Nissans normally work great together. I know I loved their manual trans oil, gave it a great feel over stock.
thanks for starting this thread. I have D4 on my 04 TL and is leaps and bounds better than OEM for our Acura tranny. Been wondering about putting D4 into the FX, and this thread puts my mind at ease. Going to do a 1x3 at my next oil change. Now to look up DIY for tranny drain and fill.
hi bro
Hi bro, D4 is the best imo...Been using it for years...I also use redline engine oil, Diff oil, power steering..etc..
