question about wiring an amp/subwoofer..?
angryfx
ny
q5
ok I recently got a subwoofer and an amp /
Today i got an Isimple dual connector pic 1
which came with the red /& white aux wire....
Now my amp connecting cable that has red white aux cable can it be put into the
red white wire of this isimple device?
without having to tap into the wires behind the
radio dash? ... so that i can just wire the power source from the battery and call it "done"
I do not know anything about electrical or wiring so please help?
I m not sure if I am even explaing my self correctly right now...
The rca (red/white cable) from the isimple should be an input...not an output. So if you got a y cable and connected it to your red/white cable from isimple...you could run music from a cell phone into the isimple and have it run throughout your system.
The rca cable from your amp is an input as well. Running it to the rca from the isimple will do nothing. You will have to cut the heads off the rca's from the amp and splice them into the correct wires from the stock Bose.
Look up wiring diagram in the stickies for help choosing correct wiring to splice into.
Sent from my Thunderbolt
hmmm ok thank you guys... trying and learning new things everyday...
Thank you somuch!!!
will try that ....
