icallyou604
- vancouver
Im installing the puddle lights and need help setting up a SPDT ON/ON switch to control the light with either ACC PWR or Domes light power.
i wrote this in another area of the forum, hoping i can get help here also.
this is what i want to achieve with jumbosrule quote.
this is my stretch diagram so far, do i need to add a relay for the 12v ACCc PWR? hate to have lights on all the time even when i turn engine off.
-----light (red wire) ----->Switch SPDT ONxxxxxxxx /ON switch
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx | xxxxxxxxxxx |
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx 12V ACC PWR xxx Domes Light
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx always on xxxxxxx on w/ lights and unlock only
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxrelay fuse ?? xxxxxxxxxxx |
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx relay fuse box same as op
here is a diagram i found for motorcycle similar setup different sources of power
12v from battery= ACC PWR ,source of switched power = domes light
Is TERMINAL #1 = red wire for light?
any benefit having relay before or after the switch? If someone could show how to put a single relay instead of 2 seperate relays would be great.
do i need to a relay to the 12v ACC PWR also, or will i only get power when i turn the ignition to acc pwr?
the relay from the OP is running to the domes and white wire going to ?
http://www.r1200gs.info/howto/images/SPDT.gif
you could tap a second wire to ACC PWR and add a manual two-way switch. One position would turn on the puddle lights no matter what the dome light is doing and the other position would tie it to dome light operation.
