Yes, the bulbs are meant to fit into the stock housing. That why you have to specify the existing bulb type, that is what they use to determine the mount that the HID bulb is in. It sounds like a lot people in this forum have gone that way, you just need to mount the ballast that the bulb uses. I haven't swapped out the headlights yet, but I'm planning on getting asset of Angel Eyes to add to the stock set.
