Problems with SES, VDC and Slip light after change of sensor
mrhuhta
Sweden
Hi i live in sweden and cant really get any help from an Infiniti dealer.
Last summer i had some problems with my cam/crankshaft sensors error code P0335, P340. I´ve ordered a couple of them and we have replaced them. It worked fine for a while. After a crash this winter my mechanic cant really get the car to work properly.
The SES, VDC OFF and SLIP LIGHT are on and he gets the error codes
P0335=crankshaft sensor that has been changed and he cant really find any more sensor to bee faulty
C1130=That there is some kind of fault reported by ECM if i undertand this correctly?
B2202 and B2205=??
All fluids checked, oil changed, brake rotors and pads changed. I´ve tried all the "trixs" i´ve read on this and other forums but with no luck. Tried to reset the ECU with the "pedal dance", it worked for a couple of minutes and then they all come back on. The mechanic have tried to reset them also, but they keep coming back. The tachometer/RPM och the dash is all jumpy but the engine does not change rpm. Also he get strange readings whila diagnosing the RPM on idle and wehicle not moving. The engine RPM is reported back as 860 and some other reading he gets is saying it is 750 at the same time. Dont really know what these readings are, but he explained that the last one is what the car reports as "wheel speed"?
The car is a FX45-03
Any help would be much appriciated.
Thanks in advance and best regards?
i had this problem also. The mechanic checked out the front wheel hubs said i had alot of dirt in there and he cleaned it and it went off. Then i hit a pot hole and it came on again and i changed the fromt wheel hub and it went off. SO could be a dirty sensor or the wheel hub. i havent had a problem since
