I cleaned my TB when I removed the upper plenum (MD spacers install also painted the plenum). I didnt have any problems moving/cleaning the butterfly, as long as you make sure its in the same position (closed) when you plug everything back in and start the motor.
there is a throttle position learn procedure here.
///799
I think cleaning the TB is a good idea because, left alone, you may experience the problems members had (hard starting, wont stay on, irregular idle). Of course work on this at your own risk.
You are so right Alan. That was going to be my approach(removing the upper plenum) but one of the TB's bolts gave me a he'll of a problem, so I decided to just do a partial cleaning of it. My goal it's to clean the whole upper plenum along with the TB.
Once again thank you so much guys for all the info.
If I didn't know about IS, I would have called a tow truck, take it to a mechanic and pay them a arm, leg,right nut, and my first unborn male child!!! LOL
