WiND DANCE
- Central Valley CA
- 2005 FX35
Guys, I was about to make a slight adjustment to the 22mm bolt for tension to the powersteering.
When I got under the car I noticed that it was gummed up with fluid? (thick, gummy, wiped off with a towel)
It was coming from the 22mm bolt area so I'm guessing the seal inside it failed. Is it time for a new rack or is this seal/area replaceable?
I'm not losing any fluid noticeably under the hood and it feels fine. Currently just above 100k miles and I'm running Valvoline Maxlife fluid w/stop leak the last 10k miles.
:at-wits-end: Just replaced both valve covers, replaced spark plugs, ordered new radiator hoses and drive belts, replaced 3 door locks..
