PLEASE HELP ! 8000K HID d2S is flickering :-(
hahahaha thats you bro? I found that on youtube:tup:
There is a solution though. You should try to mount the ballast further away from the parking sensors. You should extend the cables further, I'm sure that will fix the problem. Just buy those cable HID cable extensions. I think I've seen them on ebay before. Mount them further away.
Yeah it me :smug:
I wonder where to mount ballasts,as not much space i found suitable for Ballasts
Actually you could run them up into the engine bay. I'm doing it next week myself.
Here is the cable extensions I'm talking about:
http://cgi.ebay.com/ebaymotors/HID-...ptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
Their cheap and work good. I have some myself and have used them on other cars I have. As long as the ballasts from the foglights are nowhere near the sensors, you'll be good!
PLEASE do DIY guide ! if it helps sensors in wet weather I would like to do mine same way following DIY :tup:.
Thanks
I forgot to also mention that I already done a test to see if it was the ballast interfering with the sonar sensors and it is. If you operate the HID's outside of the bumper and the sensors are wet it doesn't act crazy. But if you put the ballast back inside the bumper it starts acting up again.
I see. Well many people would appreciate you doing DIY.
I did create HID fog DIY 09+ with removing fender trim here on board,but new DIY would be better !
