People with towing questions
I notice people asking about towing with modded FXs on here all the time.I have a Yamaha Rhino 660 side by side(1050 lbs) which I usually take places to ride with my Z71 pulling a 14 ft trailor.Well since I have wondered and many people ask on here I decided to leave the Z71 in the driveway and use the FX.It did fine just like it should of but I wasnt for sure so I did it.Took it out of auto for I could eliminate overdrive.My Fx is AWD with H&Rs and 22by9 wheels.Springs have been installed for about 7 months.If you are lowered you will need to get a drop hitch and flip it, because of clearence issues with trailor jack.Before flipping the hitch the jack on the trailor was about 2 inches from the ground.285/40 Tires also
Thank you for posting this. Appreciate it as I have asked this question several times. I'm also looking at picking up a load leveling hitch just to keep the rear from squatting so bad, and to also solve the height problem.
---------- Post added at 09:27 AM ---------- Previous post was at 09:25 AM ----------
One of these:
etrailer.com/Weight-Distribution/Draw-Tite/3205.html
With this shank to clear the bumper:
etrailer.com/Accessories-and-Parts/Draw-Tite/3210.html
I've owned my FX45 for 3yrs and have towed plenty with it. The current setup is 22's with H&R springs all around. My front springs are cut 1/2 coil to give the front end a tad amount of rake. Some of the items I've towed are my enclosed 8ft enclosed motorcycle trailer and my 16ft Seadoo boat. The car's never had issuse with towing. However, I do notice the back end squats when towing the boat but not so much that the hitch has issues with ground clearance. If you two are having ground clearance issues, I would strongly recommend getting an adjustable height tow hitch.
