PAC AAI-NIS2 Installation Issues
shadow191
Premium Member
Premium
Atlanta, GA
2007 FX35
So I finally got around to installing my PAC AAI-NIS2 unit and Nav Video box. The video unit works just fine, but I can't get audio right now. According to everything I've read, I should be able to toggle my radio button to get to the satellite radio. But when I try that, it just swaps from AM to FM. Apparently that means that the PAC unit isn't working correctly and the system doesn't detect it. I triple checked the wiring and everything seems to be correct. Since there's no lights or indicators on the box, I don't know if the unit is dead or if I'm just doing something wrong.
Any ideas on what to do or how to test the unit? I got it brand new, so hopefully it's not just a bad unit. Since it was basically plug and play, I'm not sure what could be wrong in terms of wiring.
Did you check the 'Sat/No Sat' switch on the PAC unit itself? Make sure it's the correct one or it will not work. Hopefully, you didn't get a bad unit.
I did check that, I tried both ways just in case and even followed the different operating instructions for both. Is there any other way to check if the unit is bad? I wish there was say a light or something that signalled if it was operational.
QUOTE=NopWRX;150086]Did you check the 'Sat/No Sat' switch on the PAC unit itself? Make sure it's the correct one or it will not work. Hopefully, you didn't get a bad unit.[/QUOTE]
Alright, so I'm being told by the seller that the NIS2 is incompatible with my '07 because it doesn't have the sat button (you select sat with the radio button). If this is the case, can someone tell me which model is compatible with the '07?
2007 FX35 aPAC-NIS2 installation
Did anybody try to install the aPAC-NIS2 on the 07 FX35? I dont see any connector that will fit any of the four connector that came with this unit
