- Atlanta, GA
- 2007 FX35
Anyone have any ideas on this? Couple of nights ago, I was in stop and go traffic and while inching forward, I gave the throttle a tap and nothing happened, it felt like something was slipping. CEL immediately came on and the FX felt like it was in limp mode. I go another couple of hundred feet until I can pull over and the entire time the car is struggling, like it's pulling a heavy load. After pulling over, I shut it off and checked for leaks, I thought I blew a transmission hose and lost all fluid. But that wasn't the case. And as soon as I crank the car back up, it's fine, but has the CEL. Long story short, I drove to dinner and home, another 10 miles and then pull the code which is P1764.
Not a lot of info on this code, but it's the direct clutch solenoid valve. If it's not working, the transmission won't shift and you are basically stuck in 4th gear. I found that out today when the code came back. On the highway, the car won't go above 4th and it starts in 4th as well, hence the sluggishness. I can replicate the problem anytime if I'm in stop and go traffic and I let off the brake and the car moves forward without throttle input. The instant I step on the gas, CEL comes on. If I come to a full stop and then step on the gas, it's fine and the problem won't come back until I idle again while moving. Once the car is moving, it won't happen. It's not mileage dependent, I can drive on the highway forever.
So after looking it up, it seems as if I have either a bad solenoid or it's an electrical issue. I'm leaning toward electrical because the problem goes away every time I shut the car off and restart. Something is happening at low speeds to trigger the problem. And coincidentally, I took the car in the day after this started happening to get new wheels mounted and when I went to pick it up, it was DOA. The battery cable apparently had come loose and I had no power. The shop showed me the positive connector was loose even though the bolt was bottomed out. Googling this, a lot of the Titan guys throw this code after their batteries died.
Anyone have any insight on this? I'm hoping it's just a little electrical issue that's making this happen. I'd really rather not have to swap the valve body. I have my old spare one since I swapped for Stillen, but it's a hassle and messy. And if I have to swap the VB, will that resolve my issue? I'm guessing it will since the TCM and all electrical connectors and solenoids that can cause this issue would be replaced. I saw some other posts here about other codes, but those were ABS sensors. I thought maybe the Stillen VB is incompatible since it came from a Z, but it's been working for 6 months and all my research said they were compatible down to the high/low ohm solenoids.
