As promised, here's my install for the Oznium Ultra Thin LED Dome lights. These suckers are amazingly bright. I would say at least 5 times brighter than the stock festoon bulbs (maybe even too bright). I ended up just going with the "white" LED's instead of the "warm white" or "cool white." Hopefully this will be a little more thoroughly written than my last DIY :k:
Install time: 5 minutes
Cost of LED's: $25 ea. + shipping ($5)
Purchased through Oznium.com
Tools: Your fingers
First off, examine the contents of your package to make sure you have received everything including the correct size festoon bulb. Oznium provides a multitude of adapters so these LED's will work in almost any situation.
Now that you've found the correct festoon, we'll begin removing the dome light lenses. Take a finger (or two) place on the inside lense and use your finger nails to pop the cover loose. It may help if you try turning on the light (pushing on the outside of the lense) while using your finger nails to get underneath and pop the cover.
Now that it's loose, walk it from side to side to remove. Do the exact same steps for the passenger side cover. Now with the covers removed, your stock festoon bulbs are exposed. Remove both bulbs and replace with your Oznium festoon adapter. Make sure the "red" (positive) wire is facing the hood of the vehicle.
Now connect your LED light and test to make sure everything works. Oh the brightness :glasses:
Next remove the backing to the sticky side of the LED, and place the light into position. Take note where I have placed mine as I felt this was the best location to balance out the look of the lights.
Once installed, double check everything one last time to make sure it all works and then reinstall the dome light covers. Insert the outside of the lens first and then snap the inside into place. Check to make sure both LED's work with the covers installed, too.
Congratulations, you're done!
Like I stated earlier these suckers are awesome and bright! I'll get night time pictures here soon :tonguey: Thanks!
Night time pictures. Ignore the blurriness, I have yet to master night photography with no flash...
Tools: Your fingers
