Only 1 light with Daytime running lamps
  • Thread starter Thread starter markmadness
  • Start date Start date
M
markmadness
Guest
Hi all,
after installing my amp and sub (meaning I was playing around with the battery), I noticed that only one of my headlights is on with my daytime running lights. When I turn the headlight controls to ON, everything comes on as it should, but when I turn everything to OFF, only one light stays on...
I don't think the bulb is burnt because it works in the ON position, so did I blow a fuse or something? If so, which fuse?
Any ideas?
By the way, I've found the problem for anyone who's interested.
Basically, the day time running lights (DTRL) and the parking lights are the same bulb, but seperate filaments. So I had one burnt filament in one bulb, and I replaced the bulb for $3.99 at the dealership.
