oil leak on the spark plug?
recently i decide to return back with my laser platinum NGK spark plug from iridium tip, as far i tested the platinium tips work much better and quicker acceleration but during the disambler and installing procedure i saw oil on the old sparks, so as i technical concerning there's a leak on the gasket of O-RING. i've doing research online try to find out those parts for ordering but i was unable to find it.
does any of your guys experience oil leak on the spark plug gasket? any part number?
The valve covers have integrated chambers for the spark plugs. If a chamber is leaking the only thing you can really do is replace the valve cover. Order a new gasket for the valve cover being replaced as well if you are going to replace the valve cover.
that's what i hear about it!
is cost around 400us both ones.
Thank bro for the information
