Oil drain plug washer size?
neva4self
Queens, NY
2009 FX50
Anyone know the size of the washer that goes on the oil drain plug for the 2nd Gen?
I like to know the right sizing info when I go into Pep Boys or AutoZone to buy things like this. As simple as it should be to look this up, the Pep Boys by me doesn't have a great track record for giving completely accurate parts sizing info.
I don't know the size off hand but I buy a few at a time along with filters at the Nissan Dealers they are very cheap there, if you are close to a Nissan Dealer.
Last time I was at the Nissan Dealers I just asked for the oil drain plug gasket for a 2010 FX50 and they gave me a couple at no charge. It is a pretty standard gasket with Nissans and Infinitis.
The Nissan Dealer also carries our air intake filters Part # 16546-30P00
I have found that the parts prices are quite often cheaper at the Nissan Dealers as compared to the Infiniti Dealers.
I just picked up a few from the Nissan dealer by me. I thought that they were going to be your typical flat washer these look more like crush washers. Quick question does the side with the small notch go up against the drain plug or up against the oil pan?
Yeah, I put the side with the notch (rounded edge) up against the oil pan and the side with the sharp edge against the drain plug. It dosen't slide in, the notch act like a thread that you have to screw it onto the drain plug.
