Oil Change
Man you're having a bad day with your fluid changes.. Just drain off a little oil, it's easy.
TapaTalkin'
yea tell me about it!
---------- Post added at 01:02 AM ---------- Previous post was at 12:59 AM ----------
What would happen if I don't ?
Oil will go in the crank case and aerate it and become foamy; and difficult to filter. This causes damage to various engine parts. I would just drain a little out and recheck levels.
TapaTalkin'
The ultimate reference is the oil level, you can put more or less as long as your level reading is on the designated mark on the dip stick.
Sent from my iPad
Next time just buy the 5 quart jug makes it simple
---------- Post added at 07:15 PM ---------- Previous post was at 07:13 PM ----------
Remember when checking oil level heat the car up to normal operating temperature. Turn it off and wait 15 minutes for it to drain back into the pan then check the level on the dipstick. It should be between hi and low
