oem fog light light output question
I believe there is an adjustment hole on the fog light housing. Not 100 % sure but I think I read it it somewhere as I recall someone had similar issues. But you may have to remove the housing from the bumper.
There is a screw located behind the foglight housing to raise/lower the light. The one screw/bolt is on the bottom and directly in the center of the 2 plastic bushings. It is a 10mm bolt. Cna't remember which way to adjust it for down/up.
