OEM Engine Cover...
http://www.infinitipartsusa.com/2003-Infiniti-FX35-Base-Engine-Appearance-Cover-s/7899.htm
So, from what I'm seeing, the engine cover should have these grommets to be installed with -- Brand new they're asking $98.30 for the cover which would include (I would assume) four of each grommet? Or do you just use two in a particular spot as a spacer?
---------- Post added at 03:35 PM ---------- Previous post was at 03:15 PM ----------
What color is yours? Black with silver emblem? How much? I might still want it...
the cover wont come with the hardware ///9961[/ATTACH]
Well, if it doesn't, then they will need to remedy that...because if you look at the link I provided (copied in your reply) it says on that page about the grommet and retainer:
"NOTE: Part included with engine cover."
