Nitto CrossTek tires
Ape Factory
Southwest Florida
2013 G37 IPL 2015 QX70S
After putting up with the RHO6's for far too long, a nice flat moved my tire swap up substantially. After much debate and price sourcing, I settled on Nitto's new Crosstek CUV's. I was pretty shocked to see just how much tire prices have gone up in the past year and a half, two years and the Nittos were around $870 installed by a local shop. http://www.nittocrosstek.com/tires.aspx?tt=2
I've had them on for about a month now and my initial impressions are good. It's very, very quiet compared to the RH06's. Hydroplaning resistance is very good but not stellar. Light to moderate rain is a non-issue. We're famous for our monsoons down here but I haven't had a chance to drive in that sort of weather yet. Traction in the wet is decent also as is braking. Again, far better than the RHO6's ever were.
Despite it having a pretty high UTOG rating, they have pretty good grip, good on-center feel, good turn in. The bump/skip effect of the rear suspension isn't gone but it's far, far less than with the OEM Goodyears. I believe they will wear well but time will tell. I took a few hard corners and I think I felt the sidewall rolling over ever so slightly so they're not super firm. In the past I've tooled around in some pretty hard core cars so I tend to notice the little things a bit more.
Overall dry grip is more than enough for the street and 7/10th's driving. I can't say I'd recommend them for the track at all. They're simply not a track-oriented tire. If you're looking for something that has all the OEM capabilities at a lower price, then this is a good tire. It's quieter than the Goodyears and handles just as well with what should be longer tire wear given the tire's rating.
Anyway, my .02 cents, YRMV. I also installed four new shocks and brakes all the way around, pretty much at the same time. So the above info comes with that as a caveat. If your suspension is worn, the results may be different for you.
40k update! Can't say I'll purchase the same tires again. Wet weather braking is very sub-par and the tires don't handle nearly as well as when they were new. They do wear well and are still quiet. Hydroplaning is still ok, not stellar. But their overall lack of grip is for me, disconcerting. So I can't recommend these tires any longer. They were decent for the first 10K but they were never good in the braking dept. ABS engages very easily with them wet or dry.
