I was hearing some hum from my front of the car, the faster I go the louder it sounds. At first I thought it was the cars engine, then later I thought it was something wrong with wheel balancing and alignment, so I took the car to a local wheel alignment and suspension shop, they drove test and said both front and rear wheel bearing at passenger side, as well as tie rods needed to be replaced. They quoted me $1395 +taxes for parts and labor.
Feeling like I have been hit by a rock. I did a little research online when got home and found out it's much cheaper to buy parts online and either do it myself or bring it to a cheaper local shop. Labor cost would be around 3-4 hours.
The confusion is which parts to buy. I have very little knowledge about how car works.
I have 2003 FX35 AWD.
1) Should I just replace tie rods and two wheel bearings on passenger side or replace everything (tie rods and all 4 wheel bearings)
2) Should I buy the bearing alone or whole assembly, or does it just come one style for front and one style for rear?
3) For either the bearing or whole assembly, does it matter for left/right side, or front/rear matter? I got very confuse about it. infinitipartsusa lists everything with left and right (no specify front or rear), but roockauto only says front or rear.
4) Now for tie rods. I believe tie rod is for front wheels only? (sorry for my car knowledge) So I only need to buy 2 sets
4) Do I need both inner tie rod and outer tie rod? How about other parts of tie rod?
5) Anything else do I need?
Thanks for answering some of my Newbie questions
