Need help with part name/number/advise
Renhalt
Lexington, KY
2008 fx35
So today while changing my brakes and checking suspension wear and such. I found the the passanger side front axle where it goes into the transfer case has some up and down/side to side play. It isn't leaking but definitely doesn't feel normal, there is 5-6 bolts around where it goes in and I am assuming there is a bearing/seal behind it. Does anyone know what it's called or better yet the part number and what is entailed in replacing it? Any help would be greatly appreciated. Thanks in advance!
You should be able to find the part name and number at Infiniti's official parts store. Just drill down through the menus and pull the part number from the diagrams that they have. They will also give you a cost so that you can compare various suppliers.
http://parts.infinitiusa.com/
I appreciate the input, Unfortunetly the part that I believe to be the culprit is not available. Also, I was hoping another member may have experienced the same issue and could shed more light on what all is involved in the repair.
