Hi all. I have a 2006 fx35 with the sport package.
for the past several months I've been chasing a squeak from the front end and I can't figure out what it is. It seems to be coming from the drivers side, but hitting a bump with either wheel causes it to happen, suggesting it has something to do with the sway bar. When I go into a large bump I hear one sound, and I basically hear it in reverse on the way out, if that makes sense. It's quiet in the morning, especially if its wet or dewy out. After 15minutes of driving, it comes out. It happens often, so basically any fast movement of the suspension causes a squeak, but body lean around a corner does not. If I head over a rough road, it's a constant series of short squeaks.
so far, I've tried spraying silicone lube on the sway bar bushings as well as the end links, to no avail. I've tried spraying pretty much everything to no effect. I noticed the fender liner was moving a bit, so I used cheap glue to hold it down, no effect. Finally, I brought it to a mechanic and spent more than I would like to admit to have it diagnosed, but he couldn't find it. Assuming he didn't just rip me off, that suggests that there's no play or obvious damage.
What could it be? What can I try next? Is driving me nuts!
