My project Infiniti FX45+Rotrex
Hey, if you want just post the link to any photos, but leave a space in there somewhere and I will go back and fix them.
Are you staying around the .27 bar range or is that a low starting point to be adjusted up from?
(I'm definitely not encouraging you to go higher if your system is designed for lower pressure and heat.)
Going off memory, I think other boosted FX35's have ran around 11~12 psi, (.75~.80 bar/atm)
DO NOT overboost because of my questioning. I'm just wondering why it seems low.
ordered a small roller for the compressor, I plan to raise the pressure up to 0.5
bar, if you have enough performance Rotrex.
lay out the video in the near future
