Mic install
Iron40
New Jersey
Hi all, newbie here to scene recently got 03 fx35. Read just about all the threads on the media bridge install
im prob gonna pull trigger on one,just not sure how u guys ran the mic for Bluetooth not wanting to tear out iinterior too much can it come out right thru radio bezel near the vent some info on that would be great also is it only good for iPhone looks like u could use another type droid etc thanks in advance great forum!
Welcome to :iS2:
You will need to pull the center console face plate, remove the radio stack to get to the back of the radio to install the plugs. Then find a spot behind the radio stack to lay the MB at, run the mic wire behind the dash while you have all that apart to the driver side knee panel. You will have to remove the knee panel in order to be able to reach in for the mic wire end. If you don't want to remove the knee panel you might want to stick a piece of wire up the side of the panel into the back of the radio stack hoping that it made it way to the console area behind the radio stack so that you can tape the mic wire and pull it through. Once you tuck the wire under the knee panel, continue to run the wire toward and p the driver side A pillar. I pull the A pillar off and tuck the wire behind it and the up across the headliner. Finally clip the mic to anywhere that works for you.
Thanks a lot is it easy to get the a pillar trim off , it looks like the mb can Velcro in the center console not behind the radio? Should I get the composite audio video cable and plug it to the mb don't mind the plugs to be in console
The MB comes with all the cable and wire it needs. Just pull with downward force to remove pillar trim.
Thanks and I saw the 1503 model I think is the one I will go with amazon had it they had 1501 02 and 03 it looks like I hope the 03 is the latest version but could find out for sure
