Lucas Gas Treatment
GaylordRN
Philadelphia
Hi,
Is Lucas Gas Treatment OK to use on our FX 35's?
Thanks!
Focker out
Lucas Fuel treatment complies with the federal low sulfur content requirements for use in diesel motor vehicles and nonroad, locomotive and marine diesel equipment engines.
A powerful blend of oils and additives that contain no SOLVENTS. Designed to increase power and fuel mileage and also lower exhaust emissions through a more complete combustion.
Lucas Fuel Treatment is formulated for both gasoline and diesel engines, carbureted or fuel injected. It gives your fuel system what it really needs - a blend of super slick oils and additives with a high detergent action that allows the engine to operate at maximum efficiency. Also, it cleans and lubricates the carburetor and injectors and causes the fuel to burn more thoroughly for increased power and less fuel consumption. Lucas Fuel Treatment should definitely be used in vehicles that require leaded fuel because it actually replaces the benefits of lead in gasoline without causing harmful emissions. Use it to pass smog tests. Finally, it totally neutralizes the harmful effects of low sulfur diesel fuel.
● A great tune-up in a bottle
● Cleans and lubricates the fuel system
● Neutralizes low sulfur fuel problems
● Increases power and miles per gallon by burning excess exhaust emissions
● Increases the life of pumps and injectors
Pour Lucas Fuel Treatment directly into fuel tank.
Recommended dosage is 2-3 ounces of Fuel Treatment per 10 gallons of fuel.
Exceeding the recommended dosage is not harmful to your vehicle.
Key Benefits
Directions
I dont know if it was the gas treatment or replacing the air filter or both but my MPGs went from 19.7 to 21.1. IS that what everyone is getting? I need to bump my MPGs up more!!! Any suggestions?
There was a test done on the Lucas Oil Treatment. The results were less than stellar. Basically turned out to be snake oil.. Do a search on Google and you will get some hits.
wow, is that mostly highway? coz i get about 13.8 city,
yup...highway and country roads...no stop and go
---------- Post Merged at 04:51 AM ---------- Previous Post was at 04:50 AM ----------
i will have to check it out
