LED Conversion and CAN Bus errors?
azulrium
Germany
2012 FX35 AWD
Hi all,
I've seen a lot of LED mods here, but most of them seem to be on 09-12 FX35's without the CAN-Bus system. I want to do an interior LED conversion and add additional puddle lights/courtesy lights on a '13 FX37, but if I understand correctly the new CAN-bus system would make those projects extremely difficult.
Has anybody here done a full interior LED conversion on a '13+ FX37 or QX70 with the CAN-Bus system? Were you able to work around the CAN-Bus as to not trigger the errors?
If the '13 FX is CAN-BUS, then it will be slightly different and what works on an '09 may not work. But they make lots of CAN-BUS bulbs so there should be an easy solution. It's just much more sensitive so if the resistance is off just a little there can be issues. I've got a BMW and even compatible bulbs throw errors a lot of the time. Then if the contact is dirty or it's a Tuesday, I get a bulb error. Everything functions perfectly, but it throws an error message.
