Kakumei Y-pipe test pipes
loukywells
Kentucky
I recently purchased the Y and test pipes (no catalytic converters) from Kakumei for my '05 FX35 awd. I haven't replaced the long pipe and have the stock muffler on it. I am hearing a raspy noise that I didn't hear from others on U-tube. Should I replace the long pipe w/ resonator? I didn't replace the muffler since it was replaced in an accident a few weeks ago. Should I replace the test pipe with high flow catalytic converters? Any assistance would be helpful.
removing mid-pipe (as you refer to as long pipe w/ resonator), will make it worse, because it is a good resonator on there. If you change to another mid-pipe with no resonator or another high flow resonator, you might hear more unwanted sounds.
The stock muffler also muffles sound, so any aftermarket most likely will increase the sound.
test pipes = bad for environment :rolleyes:
I would use high flow catalytic converters instead.
the y-pipe won't have much of an effect in terms of sound, maybe a bit deeper and louder. It is just less restrictive than the OEM y pipe.
So focus on the test pipes, resonator and rear muffler if you are not happy with sound.
I think rasp is common with test pipes.
V6's are more prone to drone too as they are not harmonically balanced like an I4, I6 or V8.
I had a feeling it was the test pipes...thanks. Do you have a suggestions on a high flow catalytic converters?
someone with a fx35 will have to chime in, not an option for FX45's.
i have the same y pipe + hks mid pipe + hks rear section.
Been there done that...our exhaust isn't built for the increase in air flow. I had this set up and sold my test pipes in two days. I have had berk HFCs with the invidia... Too loud and too much drone. Final setup CNT metallic 200 cell cats only $299 shipped and hks legamax. Little to no rasp, no drone, a bit louder than stock and mean at wide open throttle. Great set up. Now I'm ready for a supercharger in the spring!
Thanks for the advise. I have the cats on order so I should be good to go. However, I was looking around under the vehicle and noticed an exhaust leak at the muffler / downpipe section...crap! The section of this pipe will also need replacement. Do you have a good manufacturer of the downpipe / resonator?
Get invidia exhaust. You won't regret it. Talk to gordon
